Heat sinks for graphics card memory ?
595 Views 13 Replies 10 Participants Last post by  TheSandman
I´m wondering if these make any difference ?
I have a powercolor 4670, and it does´nt come with any.
Attachment 101192
I was thinking of cutting a chipset heatsink
Attachment 101193
into 4 equal pieces and using some thermal adhesive.
Is this a waste of time, or just go for it. ?
1 - 14 of 14 Posts
For that card, I would say it is a waste. Normally, if it didn't come with any, it most likely doesn't need them. (obviously if you are modding it or highly OCing it.) If you have them and aren't using them, go for it.
It sits on 40 Idle 55/60 gaming , I´d like to see if it can come down a bit more.
I have to go and buy the thermal adhesive this afternoon. I´ll give it a go and post some after shots.
Isn't that the core temp? I didn't think those cards had temp sensor for the RAM. Also, that is not really that hot. Still, if you have them anyways, go for it.
Yeh your right , that is core temp. Think I´ll give a go Anyway.
Keep in mind, core temps for GFX cards are not the same as CPU's GFX cards can run up into the 90C range safely. (so, 60C is not that bad)
i got some for my friends 8800gt for $4 shipped from ebay, they work.
Originally Posted by stevenma188
The answer to this question is...WHY NOT!!!
1+ for......WHY NOT!!!
lol
pointless, ram doesnt need it honestly, ram sinks are more decrative.
I ran a 6800GT no ram sinks
x1900XTX no ram sinks
8800GS OC'd no ram sinks
3870 DDR3 no ram sinks
never a problem
1 - 14 of 14 Posts
