Heater core size chart
10554 Views 5 Replies 4 Participants Last post by  wimcle
Hey guys I there was a site that sold heater cores and it had a nice list of about everyone available with size and a picture. I cant seem to find this site anymore.
Im trying to see if I can find a heater core that is more of the 320 size range because I wanna move some stuff around in my case and want a 3x120fan setup but cant go much wider then 120mm.
If anyone knows of one that falls in that size range or has a link to the site I am talking about it would be much appreciated. Thanks.
1 - 6 of 6 Posts
This is a pretty good one...Heatercore Database
Hey NP Max, hope you find a good one.
hmm, i believe it will be difficult to fine what you are looking for. When i was looking at heatercores i found that most of them are square or rectangular in shape, but are rarely 1200 mm wide one way. The only exception that i know of are the popular bonneville ones which are about 120 x 240, but again i could be wrong. Also you might want to try to go to a local scrap yard to look around, and maybe you can get a good price.
the heater core i'm using is 10.5 x 6.5 x 2.5 I have a pair on 140mm fans on it... it is awesome... added a gtx280 to the loop, no change in temps
'68 bonnie
1 - 6 of 6 Posts
