1 - 9 of 9 Posts
Hey, I have £25 left over, and I was looking for a semi-decent heatsink to go with the rig. I also need a couple of decent fans (2x120MM?) to take in some air and push some out.
System: E7500 looking to go 3.4Ghz + (silent as possible) 6GB DDR2, HD4870.
Thanks!
Cooler Master Hyper 212+
Picked mine up with 1 stock fan for ~$18 at Frys. (was a open box)
Still very cheap, very good cooler.
Good luck,
-digi
EDIT: Damn you lethal... You effing ninja'd my idea
Good luck,
-digi
Haha! I love mine... Can't wait to see how my new Sandybridge handles it.
Any other suggestions?
There is no other suggestion that can be made, the 212 is phenomenal...
It outperforms coolers well exceeding it's price and can keep pace with stuff costing more than twice as much, you simply wont find a better cooler for the price. (in fact most coolers at that price range are comparable or worse than stock)
You'll want to get another fan for it to push/pull it, but that's hardly going to break the bank.
Discussion Starter · #9 ·
One last bump... I'll be going with the 212 if I don't get any other suggestions. Thanks btw Crabid
1 - 9 of 9 Posts
