no its a single gtx 580 and I promise its not fake lol. Maybe you are forcing vsync through the nvidia control panel?Originally Posted by Yvese;15229678
Is that with SLI? If not then that's either shopped or something because my sigrig gets 60fps with those settings.
Well you must have an ultra special 580 because everyone elses 580 score within the 50-63 range at those settings and that 580 isn't even clocked high.Originally Posted by Ratjack;15229691
its the EVGA GTX 580 Superclocked edition... dont know if that makes any difference.Originally Posted by Yvese;15229772
the min start right at the start of it for some reason. then it runs fine... not sure why the small jolt in the beginning. my real minimum should be about 60 or soOriginally Posted by tjbridge;15229863
my 560 hawk at stock has 28.8 min fps using 285.38 drivers
Keep in mind he ran Heaven 2.1, not 2.5. 2.5 stresses the GPUs a lot more than 2.1 ever did.Originally Posted by Yvese;15229772
Just noticed that.Originally Posted by karmuhhhh;15229996
It is totally a dud.Originally Posted by Yvese;15230029
Just noticed that.
Was starting to wonder if my 580 was a dud![]()
I can get 68 with my 570 overclocked to my normal using speed of 850mhz, and I can get 71 with my benchmark settings of 950mhz, using 2.1 heaven, so his scores are probably right. It looks like he is just using the default settings at 1080p unless I'm missing something. Mine are also using 2.1 Where do you get 2.5 at, I haven't seen it.Originally Posted by Yvese;15229772
Quote:Originally Posted by karmuhhhh;15229961
Not too bad. About average for a slight OC 580. Here's mine for comparison, run on the same settings as yours.
wow lol my fault guys.... sorry i did not even know there was a 2.5. I will go download that version now.Originally Posted by karmuhhhh;15229996
Haha you wishOriginally Posted by karmuhhhh;15230046
Sell it to me![]()
http://www.techpowerup.com/downloads/1961/Unigine_Heaven_DX11_Benchmark_2.5.htmlOriginally Posted by bevo;15230088
920 is fine as long as voltages and temps are ok which looks like they areOriginally Posted by Ratjack;15230161
also is 920MHz a safe overclock? stable without artifacts?
For me with my temps? Yup, absolutely. For you? No.Originally Posted by Ratjack;15230161
I'll give you my card +$100!Originally Posted by Yvese;15230172
Haha you wish![]()
+1. I was just gonna raise that point.Originally Posted by karmuhhhh;15229996
what are your temps?Originally Posted by karmuhhhh;15230192
According to your OP, your card is reaching 90 degrees at full load and seems to idle at 60. That's pretty scary. I would either change your cooler, increase the airflow in your case, or both.
