1 - 14 of 14 Posts
I have a Scythe Ninja. While mounted down, it can still wiggle around a bit. My computer's been freezing lately; when it freezes it just stops responding. The sound chirps about 5 times and then nothing else on the screen moves. Could it be that my HSF is too heavy and since it can move it's jolting my CPU and causing freezes?
<div>Originally Posted by <strong>The Hundred Gunner</strong></div>
<div style="font-style:italic;">I have a Scythe Ninja. While mounted down, it can still wiggle around a bit. My computer's been freezing lately; when it freezes it just stops responding. The sound chirps about 5 times and then nothing else on the screen moves. Could it be that my HSF is too heavy and since it can move it's jolting my CPU and causing freezes?</div>
</td>
</tr></table></div>
No.
You certainly have a problem, but it is not your heatsink that is causing it.
What are your temps? It may not be seated properly.
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>Niko-Time</strong>
</div>
<div style="font-style:italic">What are your temps? It may not be seated properly.</div>
</td>
</tr>
</table>
</div>Temps are 29C idle, 34C load
That'sa little high..maybe lap it.<br />
<br />
(not high as in actually high..but for a single core on a scythe...)<br />
<br />
It doesn't move when it's not being moved...so...no, that's not your problem.
Discussion Starter #7
<tr>
<div>
Originally Posted by <strong>Sideburns</strong>
</div>
<div style="font-style:italic">That'sa little high..maybe lap it.<br />
<br />
<br />
It doesn't move when it's not being moved...so...no, that's not your problem.</div>
</td>
</tr>
</table>
</div>Well it's 130nm and OCed with some +voltage. I was just worried cuz i jolted my computer case to get the side panel back on, and that's when it froze.
You might have knocked a molex going into one of your hard drives..<br />
<br />
or a stick of your ram might have come a little bit loose, check the clip locks.
Discussion Starter #10
I've had it OCed like this for a few months and it started crashing like 2 weeks ago. I've run prime and everything's good.
Discussion Starter #12
It must have been my PSU getting more unstable since when i bought it. I had to up the voltage... Lame.
Update your CPU Microcode eventually (included in most BIOS updates)
you could always just take your system apart and then put it back together to eliminate chip creep.
1 - 14 of 14 Posts
