1 - 20 of 31 Posts
I keep getting this error every time I try booting into Tails off my USB.
Tails initramfs issue "Unable to find a medium containing a live file system
so how can i fix this problem??
what causes this issue??
It depends, can be a combination of things like:
-Didi you checked the bios settings, is the SECUREBOOT disabled, allowing other OS to boot?
-Did you tried other usb sticks, other usb hub ports?
-Did you enabled IOMMU in the bios?
-Did you formatted the usb stick with Rufus, with the right GPT/MBR partitioning?
-Did you tried the CSM, legacy boot options combinations in the bios?
I will tell you the things which i did..
the usb stick i formated with rufus with MBR partitioning
only this i did..
now i have a lot of questions..
all these things that you are telling me to do.. can i do them in ,my motherboard bios asus z87 deluuxe?
also from where i can check the bio settings for to see if the SECUREBOOT is disabled,?
also from where i can enable the IOMMU in the bios??
also i dont understand this you told me.. such as
what you mean with this/?
also i didnt tried another usb sticks because i have already one ..but the usb which i have i tested in the others usb hub ports and i have the same message as i told you.
OG AMD
Discussion Starter · #13 ·
and after i press the tails from option as you see above
after some minutes i have this mmessage
Discussion Starter · #16 ·
also i went there
after i run as external hard disk i go in tails.. it works everything
such as wifi, and etc
but when i am, trying to create one new Persistent volume
i have this message
Failed org.freedesktop.UDisk2.Error.Failed: Error creating partition on /dev/sdc: Failed to meet partition size on device '/dev/sdc' what it meaNS?? and how i can solve it??
Rectangle Azure Operating system Screenshot Font
i dont know what else to do for to fix this problem which i have
Nice job for following the Tail bootable usb guide.
You can either try what was advised in this thread.
Stop the boot with tab and remove the lines, as also shown in the picture you posted above.
Font Rectangle Screenshot Number Parallel
You can also try to disable the secure boot in the bios.
Check this guide, the option reside in the Boot bios tab.
Azure Font Electric blue Rectangle Screenshot
While you are in the bios, check around in the tabs, if you can find the IOMMU option.
If it is there and it is disabled, you can try to enable it.
Discussion Starter · #19 · (Edited)
because i dont want to confused..
i read this article and its saying that some usb sticks doesnt work in tails
and also i have this usb stick
Photograph Light Product Rectangle Font
Now you told me to Stop the boot with tab and remove the lines, as also shown in the picture you posted above.
you mean that when i go in black screen with the message
to take out the usb stick this you mean??
1 - 20 of 31 Posts
