Hi
I recently bought a corsair obsidian 800d and I thought the top fans were 140 mm so I bought a Thermochill Triple 140 mm Radiator (PA140.3)
I have never modded a case before and dont have the tools to do it or don't know which one to use. If you have any idea how I can mod the top of the case (as shown) To make fit a 140 triple radiator. also tell me the tools to use. I need tips to make the cleanest job because this case is gonna be awsome, but I made a mistake so instead of returning the items , I want to make it fit there.
Thank you
Thank you
