1 - 8 of 8 Posts
Help!!!, I need somebody, not just anybody....<br />
Thought this post was for a song <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> <br />
I tweaked you title for you <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
<br />
Over 50c is pushing it... best to either hold off on upping the vcore any or get a better HSF.
i see that your using a stock heatsink. if you don't wana spend big bux on one get a Artic cooler freezer 64 otherwise sithe Ninja
FRom what I understand the 50's is fine but over 60 is what you want to avoid.
not for the 64 moddle. they can't take much over 56 without starting to hic-up and error.
OCing and default setting temps are a bit different.<br />
OCing the 939/AM2 recommended temp is maxed @ 50c, a few more no big deal but excessive temps when OCing is not wise due to the constant speed of the circuits/switches and load.
mine idles generally at high 30's or low 40's and low 50's under load and i never have any issues whatsoever.
1 - 8 of 8 Posts
