I don't know if it's a combination of me being an idiot and having a bad chip, or both. I've tried overclocking on my own, I've tried reading a guide (didn't really help much cause it just goes over my head), but to no avail. I just can't seem to do anything right. If I go over anything past 3.2, everything seems to go screwy. I've tried messing with voltages, and whatnot but Prime95 just says NOPE after around 15 minutes every time. At stock, my temps are about 23C and at load around 44 ~ 46C. Every time I try to overclock, my temps get over 50C and then it either reboots or BSOD. What setting do I need to enable/disable? Can anyone help and show me the way! If I need to add anymore information about my setup, let me know. Everything is at default settings in the BIOS and everything is at stock except my GPU.
My specs:
CPU: 1090t @ 3.2GHz 1.4v (stock)
MOBO: ASRock 970 Extreme4
GPU: AMD 6950 Unlocked (880/1375)
HSF: Antec Kuhler H20 620
RAM: 8 GB Kingston HyperX 1600 (9-9-9-24)
PSU: 750w PC Power & Cooling
http://valid.canardpc.com/2713555
My specs:
