Help AMD 64 Athlon 4000+ OC'ing
891 Views 27 Replies 6 Participants Last post by  enzo15
i need help with my over clocking on my amd 4000+. I need to no If I have it running at 2.41 GHz and my temps are 32C idle and 40C load what settings (FSB, CPU voltage, Multiplier, and Core speed. I tried it the wrong way and it went slower. Help!!!!
:withstupi
1 - 20 of 28 Posts
fsb = 200
multi = x12
voltage = 1.55v will be fine
and those temps are fine as long as its all under 50c load
hope a helped
if not just ask me again
wont that get me a 2.40 i want to over clock it higher
right
well first things first lower your htt to x3 so that the total fsb isnt over 1000mhz
then up the fsb of the chip to 205 x12 should give ya 2.46 ghz
if pc comes on then up it another 5mhz to 210 then run a torture test like prime 95 or occt for 15mins then if no faults up it another five. but if there is faults up the vcore another notch to 1.6v and then try 215x12 =2.58 DONT GO ANY HIGHER THAN 1.6V and 1.65v if you have good cooling and temps are below 50c load try that then
fsp = 205/210/215/220
vcore = 1.55/1.6v
multi = x12
htt= x4
you can use the x4 htt up until 250 then down it to x3
ps thanx for the rep
just ask if you need help and those settings will will work
my stock speed is 2.4 ghz if I can how would i get it to 2.7
well wait a min you shouldnt need to raise the vcore i got 300mhz more on my 3200 on stock so you should get 2.7 no problem
so that would be
12x 225 = 2700mhz
htt = x4 ( 4x225) = 900mhz
opps almost forgot put yor ram on a 166 divider !!!!!!!!!!! or 333
try 225 x 12
that will give you 2.7
EDIT: you beat me to it
he might not need to put the ram on a divided
and vcore will be 1.55v
sry a bit of a mess hear it is clear
vcore 1.55v
fsb 225
multi x12
htt x4
mem divider 166
so fsb=225 mult=12 voltage=1.525 and HTT=4
yep
or the vcore 1.55v thats it
divider 166 not unless your ram can handle 225mhz i think
With all due respect...
Didn't your English teachers tell you about using caps. when starting a sentance or with proper names?
Don't shoot the messanger
I'm not all that good with gramer and mistakes too.
when I get to my gaming computer I will try these speeds and let you know how it works
THANKS SO MUCH
Hey can i ask you guys a question about my video card (6800 GS).
1 - 20 of 28 Posts
