Well I finally broke down and put together an i7 rig.
Here's the specs so far:
i7 920 D0 (stock heatsink for now)
Evga x58 3x sli
3 x 1GB OCZ Gold 1333
2 x Evga 9600 GSO 768 mb GDDR3 (for kicks and giggles)
1x WD 250Gb SE16
PCP&C 750w
Win XP pro 32bit
I was just kind of messing around with this thing a little bit and rating it's performance, which it's fast, but here the odd thing. When I checked the CPU speed, it was @ 2267MHz. So I go in to the BIOS and see that the multiplier is at 17x, with a base clock of 133. So I raise it to 20x and get the desired 2660 MHz.
So just to see how it would perform at stock clocks I ran 3dm06. It did fairly well, a little over 15,900. When I look at the results screen I noticed it said the CPU was at 2853.. SO I'm like
. Check the BIOS to make sure speedstep was disabled, which it was.
So then I rerun 3dm06 and get a result of 15411. Once again on the results page I see that it says the CPU was at 2753MHz. Why isn't the little OC it gives consistent?
FWIW, I downloaded realtemp and none of my cores ever went above 60C.
Also, does anyone know of a GOOD guide to ocing the i7? Something that'll explain with some detail what each setting does.
Evga x58 3x sli
1x WD 250Gb SE16
PCP&C 750w
Win XP pro 32bit
