1 - 5 of 5 Posts
So i i had my computer custuom bult and i went in to bios and check some things and i orderd 1800mhz kingston hyper x ram and when i view it in bios extreme tweaker it says target DRAM frequency 1333mhz did thay**** me over and install 1333mhz ram insted?
Super Moderator
Please avoid making multiple threads for the same thing. Be patient, all right?
Open your case and check the ram itself. You usually need to set its speeds manually in the bios.
Discussion Starter #4
Were do i do that?
I had this problem, you have 2 options
1. You have to set the Speed manually (as my RAM is rated @ 1600 but the BIOS set to 1333 [I set it to 2000 myself anyway])
2. You need to put the RAM in the correct slots, once I put mine wrong (instead of putting a stick in a white slot I put it in a blue slot) and it wont POST when set above 1333.
Try the 1st, if it doesnt work, do the 2nd.
1 - 5 of 5 Posts
