1 - 13 of 13 Posts
Ok, so today I decided to mess with overclocking my shiny 3.2 GHz P4...but I was lazy, and I decided to use the Easy Tune utility included with my Gigabyte mobo. I was lazy enough for a while just to use the auto feature...crashed it, went into BIOS, upped voltages...got back into Windows. Then I started tinkering myself, I upped the FSB, then adjusted the RAM freqs to run 1:1.
When I did that, it asked me to reboot. So I did...but it froze. So I hit the reset switch on my case, and it went into some screen I never saw that said BIOS auto recovery with a little progress bar...that finished, and it auto rebooted. But...now it's not even posting. It's not giving me a BIOS screen or anything.
I popped the CMOS battery...no good. That's the only thing I could think of doing really.
My question now is can I fix this? or are my BIOS completely shot, somehow? If they're irreparably shot, I can always just buy a nice 865PE mobo off my friend...would be an upgrade, but I don't really wanna spend money.
First take out your memory and boot. If you here a beep from the absense of the memory your mobo is fine. Just go to Gigabyte's website and download a emergency recovery BIOS. Put it on a floppy, and then take out your jumper. When you boot, the BIOS will install and you will be all set!
well, overclocking on a 848i chipset wasnt the greatest idea to start... As for your bios... oh boy i think your mobo might be shot if you have tried re-setting the CMOS multiple times.
Discussion Starter #5
Originally Posted by pauldovi
Yes, when you take the battery out... leave it out for a while (1-2 hours)
I've heard people say like pop it for 30 seconds...I did it twice for a few mins. I don't think it has a jumper, it has pins for it I believe, but I've never seen a jumper. Every time I've failed at overclocking, I've just popped the battery.
Anyway, I'll mess with the mem now.
Hi Filip,
Sorry to hear about your bad flash. I'm assuming you still have internet access since you posted here. 3 things you can do:
1) I thought most Gigabyte motherboards had the dual BIOS function. My older GA-8INXP did, but then again I don't know which board you have. Does yours have the backup BIOS??
2) You can contact Jack at http://www.badflash.com or [email protected] send him your EPROM chip and instructions where and what BIOS version you want and he'll fix you up. I've used him to save 2 of my motherboards in the past. I was able to save a ASUS A7V-266E and a ASUS P3B slot 1.
3) Buy your friends board - :)
I hope this helped,
Discussion Starter #7
Well, pulled the memory, instant bishing from my system; repetitive beeping...means board isn't shot
Hmm does it really matter if I pop the battery instead of using a jumper? I can probably pull a jumper from somewhere if it really matters.
It does suck for overclocking, very limited options, but I ran my 2.4 Northwood at 3.0 for months fine with it.
Your mobo is fine. You prolly just need to recover the BIOS. Follow Gigabyte instructions on the recovery.
Discussion Starter #9
I looked on their site and found the BIOS for my board, I just didn't find anything specifically labeled 'emergency' or anything like you said. Can I just stick a floppy with the BIOS image in my floppy drive and it'll flash it automatically?
Discussion Starter #11
Hmm they don't really have anything like that...no bootable ROM file or anything.
Further help? How the hell do I relfash the BIOS on a computer that won't even post...
look up boot block floppp or boot block bios recovery,I googled "how to fix a corrupt bios" and found a site somewheres,i will looks for it,if i find it later,i will edit this message and repost
**I found the website,i hope i helped u,my last mobo did this to,but i couldnt fix it becuz everything fried,i would of needed and isa slot and no really new mobos use them,Anyhow heres the link
http://www.wimsbios.com/HTML1/faq.html#q9
I also had the same prob. but I have a jumper on my board, and just short across the 2 pins with needle nose for about 3-4 seconds.
-bobkat
1 - 13 of 13 Posts
