HELP!!! blue screen with mamory_management
438 Views 8 Replies 6 Participants Last post by  ProjecT TimeZ
6
For the past 3 weeks, I've been getting blue screens with memory_management on it left and right. At least 5 times a day......in 5 minute gaps
So, today I ran the windows memory diagnostic (mtinst).
It failed the Stride6, WMATS+, WINVC, INVC, and stopped on the LRAND test, it gave me this error:
"Internal error: Can't locate 004AFF9C in DeregisterFixup"
Does this mean I need new ram? or is it fixable? or is it the ram slot on the mobo its self thats broken???
I even set my ram back to default, not overclocked anymore..
Help Please?!?!
1 - 9 of 9 Posts
Test each stick individually with MemTest.
http://www.memtest.org/
That will tell you for sure which stick is bad. Then you'll need to RMA that stick.
You should run "memtest", then you can make sure if the ram is the problem or not.
I suspect a stick went south. Use memtest to test them. You can try resetting cmos. That sometimes works.
"Mamory" or "memory?"
Slightly different meanings, brah
That too
mEmory...
my bad
OMG Thanx for the help guys!!!!
it turns out only one of the sticks were bad,
DRINKS ON ME!!
Send me $5, and we'll see about that deal...
Glad you fixed it.
1 - 9 of 9 Posts
