So here's where I sit...I have six fans pushing air through three radiators (360, 240, 120) and I'm using the Koolance 452X dual-bay reservoir/pump combo w/twin 450 pumps (very quiet on high too...superb pump/reservoir deal although a bit of a pain to prime). I have a 1250W PSU so getting power isn't too much an issue. I'm getting ready to install a ASUS Rampage III Formula (I shorted out my eVGA X58 board the other day...).
What are your recommendations for pump/fan control? Currently i have manual fan speed control using a simple 4-fan controller where I wired up all three of my 360 fans into one connection, the two 240 fans as one connection and the 120 by itself. Pumps are straight molex w/o control right now. I'm gobbling up Martin's posts on controllers and DIY wiring but I'm not sure what's the best approach. Sure...I could go balls-out w/hi-end setup but I'd be happy with just a simple controller setup. I'm currently looking at the TMS200 solution from Koolance but I don't want to go any higher up (in price). Thoughts?
