1 - 11 of 11 Posts
Hi, my sig rig wont boot into windows anymore... just before going to windows, it says my C drive needs to be checked and that i have 10sec to press something to cancel. if i press something the system freezes and if i wait for the checking the system freezes too ... i tried to run the "checking" overnight but hmmm yeah its really frozen :/ ... is my C300 dead ? what are my options ?
Sent from my iPhone using Tapatalk
You could set your boot priority to boot from your seagate HD. If you don't have windows installed on the seagate, put the windows install disk in and try installing windows on it to see if your system will boot from the seagate once windows is installed.
At that point if your system will boot from the seagate, you very well may have a bad SSD.
i bought it like 2 months ago and it was working fine ... how can it turn bad all of the sudden ?
When I was researching my sig rig I ran across alot of reports of them just going bad out of the blue. I went ahead and got one anyway, but the reports of bad ones are out there.
You could ask the guys over at the crucial forums about your problem. Lots of very informative crucial employees post solutions to users problems all the time there.
Because it can?
Sounds dead to me but maybe the Crucial forums can help.
I've had 3 Intel G2 SSDs die on me and one of those was no good right out of the box.
Let us know how the Crucial RMA goes.
Originally Posted by Jomboh;11926516
I called tech support. My SSD is dead and they are sending another one. weird they didnt even ask for invoice, date of purchase or S/N o_O ...
Bad outcome, but atleast you figured it out.
1 - 11 of 11 Posts
