1 - 10 of 10 Posts
I need a case with room for a thick 120.5 or 120.6 wc set-up. I need to cool ~600w of CPU and GPU single loop. Suggestions please.
Obviously there are other hardware factors but i can kinda getta feel. Major mods not preferred. For example, a switch may be too tite for me while a corsair 540 may wirk with thin rads
a 900d is ~$330 and would be 120.4 x2.
Needs to locate mcp35x pump with mcr stack res, needs at least 2 free 5.25 bays for dvd drive and fan controller. no bay res.
sorry for the multi posts and lack of info.
Enthoo Primo ?
Discussion Starter · #8 ·
Originally Posted by Ironsmack View Post
Enthoo Primo ?
perhaps, but i dont like how the front is chopped up into a 120.2 seg on front and side with 120.3 up top i think. itd be nice to do 120.3 and 120.3, front top. its a strong contender for all that case at that price.
Discussion Starter · #9 ·
the more I custom build Case Labs and look at Lian Li, Silverstone's, Phantek's, etc... For the money, the Corsair 900D can do 120.4 top and bottom, 120.3 front, and another 120.2 on side. Can it be beat?
Phanteks case is top. I had one, don't anymore. It is quite large. Personally had a thick 420 and 480 in the top and bottom. With that setup I had still could have done a side 240, possibly front 240, and rear single rad. Case has a pump bracket which worked quite well to dampen vibrations. Also don't forget the pwm hub...
Sent from my SM-N900P using Tapatalk
1 - 10 of 10 Posts
