1 - 6 of 6 Posts
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/hda1 / ext3 defaults,errors=remount-ro 0 1
/dev/hda5 none swap sw 0 0
/dev/hdd /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/hdb1 /media/hdb1 vfat defaults 0 0
that is my current fstab.. so the hdb1 is the drive in question.. it was a drive i had in a usb disk.. its fat32 partition with the setup the way it now .. it will give me read access but i cant write or delete to it.. it says it is owned by root and the group is root.. i wish to be able to have total control of this drive with out having to sudo in the terminal.. i rather use gnome with my normal account.. so how can i fix this..
Use Gparted to redo the partition. It might sort it out.
redo it how.. it has all my data on it.. im pretty sure its as simple as a chown command or a chmod command but i dont know how to use those
"man chmod" or "man chown" or "man chgrp" or "info chmod" can tell you everything you'd every need to know about command.
I'd try this though:
/dev/hdb1 /media/hdb1 vfat noauto,user,rw 0 0
Then you can type "mount /media/hd1" and you'll have read and write permissions.
Discussion Starter #5
actually i just fixed it.. i changed it to the following
/dev/hdb1 /media/hdb1 vfat user,fmask=0111,dmask=0000 0 0
and that seemed to work wonders for me..
Cool, I had the same problem a little while back.
1 - 6 of 6 Posts
