1 - 6 of 6 Posts
i just got a new E6300 and a P5B Deluxe and ill be getting the Scythe Infinity to overclock paste 3Ghz mark hopefully. which of these rams are better for overclocking and can get closer to 1000mhz...<br />
<br />
1. GEIL <b>GX22GB5300SDC</b> PC2-5300 667MHz Ultra DDR2 (3-4-4-8)<br />
2. OCZ <b>OCZ2P800R22GK</b> EL DDR2 PC-6400, 800mhz, XTC Revision 2, CL4 (4-4-4-15)<br />
3. OCZ <b>OCZ2SOE8002GK</b> PC2-6400 800mhz Special Ops Edition (5-5-5-12)<br />
4. G.Skill <b>F2-6400CL4D-2GBPK</b> PC2-6400 800mhz (4-4-4-12)<br />
5. G.Skill <b>F2-5400PHU2-2GBLA</b> PC2-6400 800mhz (4-4-4-12)<br />
6. Patriot <b>PDC22G6400LLK</b> PC2-6400 800mhz (4-4-4-12)<br />
<br />
Please help me choose between these rams, it'll be good if you can recommend me a ram thats better between those for the same price range. <br />
<br />
Dont tell me to get a G.Skill HZ series cause thats over my budget.
Go for #4
how far can #4 overclock? i never seen anyone overclocking that ram before. any other suggestions from different people?
My vote goes to #2.<br><br>
That's my choice between those choices, otherwise the G.Skill DDR2 800 HZ stuff, with the black heat-sinks.
My vote goes for #4...If you want to step out on a limb and buy some great overclocking DDR, then you might want to look at these:<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820609026" target="_blank">http://www.newegg.com/Product/Produc...82E16820609026</a><br><br>
PS - Google these sticks for reviews and you'll see what I mean...they really do FLY....<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
I would take the GEIL due to the tighter timings, you can always loosen them up and go higher. But that is my opinion on it. I dont know DDR2 is better with a overall higher mhz or tighter timings.<br><br>
pink
1 - 6 of 6 Posts
