Originally Posted by dani
nah i got the 1gb kit 2x512mb from pqi
Not to burst your bubble, but you may be somewhat limited with those 4.0-4-4-12 timings for maxing out your overclock?
However low latency DDR ll dimms are very expensive.
Check out my Memory ( PDP XBL PC2-5600"Patriot") twin matched 2x512 and they kick butt at 3.0-2-2-3 global bandwidth score 52,000 @ 1kb but they cost?
If you get those PQI's and you add more Memory sticks later down the line you will not be able to increase your speed beyond your lowest dimms? you knew that prob? anyway good luck with the PQI the Price is very reasonable.
