1 - 11 of 11 Posts
After I turn on my computer, it starts to load windows. Once its done...the computer restarts!<img src="/images/smilies/mad.gif" border="0" alt="" title="Mad" class="inlineimg" /> every setting is back to normal but it just keeps restarting. SOMEONE PLEASE HELP ME!
The problem could be a few different things as I have had this happen and I know how fustrating it can be.<br />
<br />
With mine it turned out to be the CPU was overheating and I got a Big Typhoon and moved my rig to a cooler part of my room and it fixed the problem.<br />
<br />
If you can Check the temps in your bios and post them here.<br />
<br />
Also try starting up your rig with barebones - CPU, 1 Stick of RAM, GPU + HDD and see if that helps at all and from this you can troubleshoot and find out which of the components is causing the problems <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /><br />
<br />
Hope this helps<br />
<br />
Mad <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I bet one of your drivers is erroing out and cauing a restart on error. Pres f8 or whatever the safemode button is and click on boot and hault on no errors. this will boot windows and not restart when it doesn't run into an error and report if any the error and what is causing it .
Is it a freshly built pc or was it working previously?
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>Niko-Time</strong>
</div>
<div style="font-style:italic">Is it a freshly built pc or was it working previously?</div>
</td>
</tr>
</table>
</div> yeah, is a freshly built computer and it was working
Discussion Starter #6
<tr>
<div>
Originally Posted by <strong>BigpoppaFrary</strong>
</div>
<div style="font-style:italic">I bet one of your drivers is erroing out and cauing a restart on error. Pres f8 or whatever the safemode button is and click on boot and hault on no errors. this will boot windows and not restart when it doesn't run into an error and report if any the error and what is causing it .</div>
</td>
</tr>
</table>
</div>do you think that it could be a Mobo driver?
Oohh, I hate it when that happens to me. It really makes me throb with anger. Usually I leave my laptop for a day or so, and it somehow sorts itself out.<br />
It's probably a little Windows driver, or something. One time when it happened to me (3 weeks ago) I took everything that was connected to my laptop externally out (except the power cable) and it seemed to work fine when I restarted it.<br />
Try that with yours. It's just a thought, but I like helping people solve problems.
Discussion Starter #8
No matter what I do...It keeps restarting!<br>
What Should I do?
Did you take everything out, and try it then?
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>jakeo772005</strong>
</div>
<div style="font-style:italic">Did you take everything out, and try it then?</div>
</td>
</tr>
</table>
</div>yes...
Discussion Starter #11
Thankyou everybody for your hard work, The computer is back on line!<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
1 - 11 of 11 Posts
