1 - 7 of 7 Posts
Hai,
i can't get my Corsair TwinX 1024 C2 XMS PC3200 memory higher overclocked then, 205 Mhz, standard is 200, omg that sucks.
While other people get 238Mhz, i don't have a clue why it doesnt goe higher with me, i have played with the voltages and timings but never higher then 205 mhz, at 210 windows doesnt even start up.
Weird ****, help me plz
What revision are they ?
My TWINX1024 3200C2 rev 5.1 utilises CH-5 IC's and will do 214-217Mhz at 2-3-3-6 on 2.7V but beyond that no matter the loosening of the timmings it is a no go for stability.
Discussion Starter #6
Dunno about the revision but i managed to get it to 220 mhz now with clocks 2,5-3-3-5 DRAM idle timer 16 the rest of the options arent there with my motherboard.
Do any of u know what voltage i would set best for my cpu? Running at about this speed, standard voltage is 1.4v P4 3.0GHz prescott.
Thx
Discussion Starter #7
Ok i managed to get the mem at 2,5-3-3-5 @ 2.85V any1 got a suggestion about what cpu voltage i must use on my P4 3.0GHz Prescott, standard is 1.4V iv putten it at 1.5V now. I will start prime 95 testing now, i hope it's stable.
1 - 7 of 7 Posts
