I have two 128G crucial m4 ssd and was running them in raid 0. Didn't know that firmware upgrades were important so tried to install them with no sucess. I started at the easiest "method" by just running the update without any changes to the hardest. Currently I have my computer is running off of my HHD while my ssd's flap in the wind. In the last attempt I made, I cloned my OS etc onto my HHD and then broke the RAID in the raid config and set the EFI/BIOS to IDE, formatted both ssd's, made the boot disk, and rebooted. I got the same response as I always have "finding disks...". I've tried only one disk plugged in at a time. I've tried moving the SATA port physically. The two ports that the drives are connected to are dr0 and dr1. This my first build and I prolly have a lot to learn, I would really appreciate any help that anyone can give. Thank you!
MOBO: asus maximus iv extreme-z
SSD: 2 X Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
OS: Windows 7 64bit
CPU: i7 2600k
OS: Windows 7 64bit
CPU: i7 2600k
