1 - 11 of 11 Posts
i am buying some DDR3 1.6Ghz ram today with an asus crosshair IV
but i need to quadruple check which ram is the best for me.
i have a LOW budjet. the price of the ram must NOT go over 114 bucks. including shipping. i am buying from newegg, because tigerdirect has overpriced stuff for some reason.
these are my choices:
G.SKILL Ripjaws
its cheaper and it will look incredible in the MB(red black MB+red black ram+red black GPU FTW), but im worried it might not fit with my large CPU cooler hanging over the first 2 DIMMs
G.SKILL ECO
10 dollars more
low profile, and i have heard that these work with AMD CPU better
so what should i choose?
i dont want to **** up my PC like i did in my first build (i bought bad case, defective MB, and defective GPU)
so plz help me out i want to use my real PC instead of my mom's lol
Either kit should work fine, just go with the lowest latency with highest clock speed.
Reactions: Enfluenza
I personally have some ripjaws, and I love them. Never had any problems so far with them.
Also on the look of the ripjaws, the picture son newegg really don't do them justice. They are a really nice looking metallic red. Would look great with your setup. The heat sinks are pretty tall on them though. I have just enough space to fit 2 more sticks into my last dimm slots.
Discussion Starter · #8 ·
i think i might go with the ECOs.
i wont be OC'ing ram much anyway (i never done it b4, im too paranoid
low profile ram will be great if i decide to go with a larger cooler or someting
btw this ram runs perfectly fine with AMD BE CPUs right?
ECO's indeed... if you wanna have an idea of how far you can take these babies, have a look at my sig
1 - 11 of 11 Posts
