alright, Ive built 22 of these thingss, very cramped. the aprevia x q-pack only takes a mini atx board, BUT it has a slide out mobo tray s installation is EASY!
There is only room for 2 opticals, 2 HDDs, 1 case fan, 2 floppy drives, and I think 4 PCI comps.
Its a very sturdy case, if you get it, tighten down and maybe reinforce the screws and mounts for the handle, although I have carried these by the handle, but only with one HDD and one optical in them.
I have also found in some of these cases the power button shorts itself on the aluminum casing, to remedy that, take off the front plate and put electrical tape on the exposed wires on the back of the power button. (you have to remove the front plate to reinforce the handle anyways, so do both at once)
other than those 2 nuances, its a pretty durable case, and you can get even better airflow by adding a blow hole fan and/or a front case fan, you just gotta be creative with a dremel.
Id never use the case because I have 5 HDDs in my main rig. but for lan parties you dont need 1TB of drive space, all you need is a competant mini atx board and a good video card (since Ive never seen a mini board with dual video card slots, I think that is out of the question here)
