1 - 5 of 5 Posts
for some reason i cant post this in FAQ's but what is a good program that will change my theme,icons,ect....<br><br><br><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
Retired
<div>Originally Posted by <strong>unknownSCL</strong> <a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1393112#post1393112"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">for some reason i cant post this in FAQ's but what is a good program that will change my theme,icons,ect....<br><br><br><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"></div>
</td>
</tr></table></div>
First off, FAQ's is a Forum for Guides, not for frequently asked questions, though I can understand why you got that confused. You might try Windowsblinds for changing your themes, and stardock I believe it is for changing your Icons. You can also change program icons through the registry I beleive, though I do not have any knowledge on how to do that, you might try google. Good luck.
thanks.
You might also want to check out the FAQs on how to change the XP skin the Media Center flavor or even the Vista.<br><br>
I'm using one of the Vista skins and its very aesthetically pleasing.
1 - 5 of 5 Posts
