1 - 11 of 11 Posts
I want opinions on the best RAID 5 card I can get with expandability. I am slowly building up a 20 TB RAID for storing blu-ray movies in HQ. Here are the requirements:
- Expandable array (I don't want to lose my data every additional hard drive, I am also not buying 10 x 2 TB hard drives at once, and I will be expanding once I get more and more movies.
- RAID 5 support (I need redundancy, I don't care so much about speed)
- Support for 10 hard drives at least
Much appreciated, and +Rep to useful information about the subject and suggestions.
I love Adaptec RAID controllers.......
I have one.
Downside:EXPENSIVE
Adaptec RAID 51645-Yeah I know that it has 16 internal, but maybe you will add more HDDs.?.?
Adaptec RAID 51245-This one has 12 internal.
Thanks for the suggestions, however the are EXTREMELY expensive. I can see why, but $700-$800 for a RAID card is too much for me.
Intel Extreme 1366
Sadly...RAID cards are always going to be expensive...brand new. It'd be best to find one used if you're wanting to spend less money.
As I suggested in another thread...try to find yourself an Areca ARC-1230 or 1260. If you're lucky and patient enough...you may be able to find one at a decent used price (found my 1260 for $350).
Linux Lobbyist
The PERC 5/e is a good choice, but get the PERC 6/e if you can, especially if you're going to 10 drives. Hit eBay - you should be able to get one for $200 or less; they're common because they are pulled from retired Dell servers, hence the cheap price.
Are you sure you're looking for the 5/e or 6/e? That card requires a connection to an external disk box, or to the external connection on a SAS expander. The PERC 5/i and 6/i are the internal models, but they will only see 8 physical drives unless you replace the firmware with LSI firmware.
Discussion Starter · #6 ·
Sorry for the late bump, I put the project on hold till I got my first set of hard drives. I did mean internal sorry.
Whats the difference between PERC 6/i and PERC 5/i?
Linux Lobbyist
The other different is performance. The PERC 6/i is a native PCIe device, while the PERC 5/i has an internal PCI-X bridge, which limits it to 500MB/sec on writes. One good thing about the 5/i is that it can be flashed with LSI firmware, which should allow it to see more than 8 internal drives.
Discussion Starter · #9 ·
It sounds and looks by the link posted by Shub that the PERC 6/i is a better choice. Is it possible to allow more than 8 drives with the PERC 6/i? such as doing the flash you mentioned for PERC 5/i?
Linux Lobbyist
By rights, it is the better card, which why I have one.
I'm not sure that there is an LSI firmware that will work on the PERC 6/i. You might want to ask in the sticky PERC 5/i & 6/i thread.
Reactions: Limes
Discussion Starter · #11 ·
Alright, I asked there as well. +Rep to you and everyone who posted.
If anyone knows, feel free to bump this thread.
1 - 11 of 11 Posts
