Okay guys here's the deal; Just built my first rig from scratch...I had previously done mods on "boxed" pc's but nothing like this.
System specs:
mobo:
Brand GIGABYTE
Model GA-EP45-UD3R
Supported CPU
CPU Socket Type LGA 775
CPU Type Quad-core / Core 2 Extreme / Core 2 Duo / Pentium
FSB 1600/1333MHz
Chipsets
North Bridge Intel P45
South Bridge Intel ICH10R
Memory
Number of Memory Slots 4Ã-240pin
Memory Standard DDR2 1366+/1066
Maximum Memory Supported 16GB
Channel Supported Dual Channel
cpu:
Brand Intel
Processors Type Desktop
Series Core 2 Duo
Model BX80571E7400
CPU Socket Type
Tech Spec
Core Wolfdale
Multi-Core Dual-Core
Name Core 2 Duo E7400
Operating Frequency 2.8GHz
FSB 1066MHz
L2 Cache 3MB
Manufacturing Tech 45 nm
64 bit Support Yes
Virtualization Technology Support No
Voltage 0.85V - 1.3625V
Thermal Power 65W
case:
Brand RAIDMAX
Series Tornado
Model ATX-238WG
Spec
Type ATX Mid Tower
Color Black
Case Material SECC Steel
With Power Supply No
Power Supply No
Motherboard Compatibility ATX
With Side Panel Window Yes
Video card:
Brand XF
Interface PCI Express 2.0 x16
Chipset
Chipset Manufacturer NVIDIA
GPU GeForce 9500 GT
Core clock 550MHz
Memory Clock 800MHz
Memory Size 1GB
Memory Interface 128-bit
Memory Type GDDR2
3D API
DirectX DirectX 10
OpenGL OpenGL 2.1
RAM:
Brand Kingston HyperX
Model KHX8500AD2K2/4G
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 4GB (2 x 2GB)
Speed DDR2 1066 (PC2 8500)
Cas Latency 7
Timing 7-7-7-20
Voltage 2.0V
Multi-channel Kit Dual Channel Kit
Recommend Use High Performance or Gaming Memory
*Copied directly from the packages*
Everything else is pretty much reused from my old pc. My psu is a 500W Silencer.
Windows 7 sees my cpu running way below the 2.8GHz I want it (expected it) to run at. And in my BIOS the RAM is also way under clocked.
But these BIOS are very confusing. I change one thing and something else will change along with it.
What I am looking for is some help to get my cpu and RAM running at the rated speeds of 2.8GHz and 1066. Not really an overclock but just getting them up to speed I guess.
Sorry for the long post but I wanted to provide as much info as possible.
System specs:
mobo:
Brand GIGABYTE
Model GA-EP45-UD3R
Supported CPU
FSB 1600/1333MHz
Chipsets
Memory
cpu:
Brand Intel
Series Core 2 Duo
Model BX80571E7400
CPU Socket Type
Tech Spec
Core Wolfdale
FSB 1066MHz
L2 Cache 3MB
64 bit Support Yes
Thermal Power 65W
case:
Brand RAIDMAX
Series Tornado
Model ATX-238WG
Spec
Type ATX Mid Tower
Color Black
Power Supply No
Video card:
Brand XF
Chipset
GPU GeForce 9500 GT
Core clock 550MHz
Memory Clock 800MHz
Memory Size 1GB
Memory Type GDDR2
3D API
DirectX DirectX 10
OpenGL OpenGL 2.1
RAM:
Tech Spec
Cas Latency 7
Timing 7-7-7-20
Voltage 2.0V
