1 - 19 of 19 Posts
Hi all overclockers
Know that its are like 2 more threds of how to flash a x600 pro to x600 xt but still dont anderstand (only 14 year old boy plz help...)
1. I looked at www.teachpowerup.com for a x600 xt bios. But i only found a GeCube X600 xt and i have a asus x600 pro. Is that any problem? I edited the bios to 550/300 (thats what my card can handel), And the memmory timings exactly as my curret. Are i ready to flash?
2. How do i flash?
3. And what happnd if tha flash faild!? do i have to buy a new card? (agin only 14 year old no money)
1. You should be, but You/I need some ensurance (I'm not 100% sure) just to be safe.
2. Can't answer on that one, sorry. Never done it on ATi cardss.
3. Normally you can do what's called a "blind flash", which basically does the same as 2. - just that it reverses the failures.
u can flash the card again.. just get another display device... ie.. on board, or pci... and try it again... just be sure to backup the original before overwriting it
Nothing should be a problem about temps. The worst they can do it doing artifacts, and it is possible (even though it's artifacting) to reflash it.
Discussion Starter #8
Or i found a Asus x600 xt on teacpowerup but its are an 128 mb and i have 256. Can i change it using R.A.B.I.T and flash?
Discussion Starter #11
Originally Posted by selectodude
If you bump again, someone will have to take you out back and shoot you in the head.
Wow...sure dude. But still ned help.
OK. really there is no reall point to flashing that card. besides the fact it detects as a Xt instead of a Pro. so i wouldn't bother myself. just OC the sucker to the max. u will get the same performace. trust me. i have a 9600 XT Ultra and a 9600 pro (all the X600 are just 9600 with better memory speeds and PCI-E) i OCed them to the same speed and i got the ezact same performace. so i would just OC. save u the trouble of mucking around with flashing
Discussion Starter #13
ok, but i want to flash. It mena verrry mutch to me
hehehee you know, i dont have i good card so why not own at least a x600 xt :S. And ya...son gona buy a 1950 xtx.....
well i have never flashed a PCI-E card. so i wouldn't know how. soz mate
I was talking to my mate today and he has one. he is going to email me over the bios in the next 8 hours or so. as soon as he does. i will upload the bios onto the net.
You'll need to upgrade your power supply to get that card.
I reckon he would get away with it. i have seen them run on a 250watt power supply. but all the same an upgrade would b good
Discussion Starter #19
Thank you!!!! I am waiting for the bios......
1 - 19 of 19 Posts
