1 - 12 of 12 Posts
Hi Overclock,
Here is the idea.
My friend has 800$ to spend on a computer and we are trying to get the best performance for $. This is strictly for GAMING, nothing else.
I told him that here we will have help from the best of the best
We live in California.
He needs:
Processor
Ram
Hard drive
Video card
Cooler
Power supply
DVD drive
He has;
Windows
Keyboard/mice
Will
Please any help will be really appreciate it.
He doesn't care if it is intel/amd he just wants to get the best possible gaming pc for 800$
Thank you again
Gabriel.
Originally Posted by Realityntatt View Post
Yes I forgot also dvd drive.
Thank you
ok working on a build for you right now
what rez is he planing gameing at?
well here is what I came up with
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102987
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147094
you will need to put 2 of those in your cart ^^^^
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
there are 2 promo codes you need to make sure you enter RW15PSUM for the psu and EMCNEJB238 for the HDD
total with shipping $815.56 that being said if you do some shopping around you could prob save a little more
He just told me that he needs a monitor as well -.- 1080p preferred.
facepalm well that completely fs that build
anything else before I redo this?
Go with the 2500K, no need for 3570K, and drops the cost, also get a Z68 board if they are cheaper. If you have a Microcenter near you, they have both for cheaper than newegg, but its in-store pickup only.
no, he told me thats all he needs.
Is $800 the absolute max I cant seem to find enough deals with out killing performance to get it under 850 with monitor
ok well here is what I came up with then
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009306
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
as before you need these X2 ^^^^^
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157279
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Promo codes EMCNEJB45, EMCNEJB238, and RW15PSUM
total with shipping $813.74
after the $15 mir on the graphics card = $798.74
Discussion Starter #11
He says he can extended to 900$
Thank you for your help
1 - 12 of 12 Posts
