21 - 40 of 49 Posts
Discussion Starter #21
I am also searchin in control panel to find new hardware, but it is not finding anything<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Do you have a digi cam? Can you snap some pics of the various BIOS screens and post them?<br />
<br />
That might help.
What is the brand/model of that motherboard?
Discussion Starter #24
nope only on my phone<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> and that costs lpads to send.......In the main page you have main, advanced , power, boot, and under advanced is the onboard chipset congiguration, give me 5 and I will be back with more info
Bod ***s rock
can you fill in you system spec by using the user cp so we can assist you better
<tr>
<div>
Originally Posted by <strong>rudolfsun</strong>
</div>
<div style="font-style:italic">the mother board is asus V5RD£-VM rev1.xx</div>
</td>
</tr>
</table>
</div>Is that the P5RD2-VM?
Discussion Starter #29
right in the BIOS you have<br />
Onboard device config.<br />
sub menus are:<br />
Serial Port 1 Address<br />
Parralel Port Address<br />
Parallel Port mod<br />
Epp Version<br />
ECP Mode
Check out this thread on 3d ave. sounds like your ordeal...<br />
<a href="http://www.3davenue.com/forum/index.php?PHPSESSID=e052143d8734fd71146c6f5df9d08945&topic=10.new" target="_blank">http://www.3davenue.com/forum/index....5&topic=10.new</a><br />
And is the PSU you bought on the list at ati ?...<br />
<a href="http://ati.amd.com/technology/crossfire/buildyourown2.html" target="_blank">http://ati.amd.com/technology/crossf...dyourown2.html</a>
Discussion Starter #31
also in adcanced is<br />
Chipset<br />
sub menus are :<br />
Northbridgr setup<br />
SouthBridge setup<br />
sub menus for north bridge:<br />
IGD parallel Port=IGD or PEG/IGD or PCI IGD<br />
#<br />
then lots of IRQ Port thingies I don't understand
Ok... go in the BIOS. Go to the 'Advanced' menu, and select 'Chipset' and then 'Northbridge'. You'll see an option that says 'Boot Graphics Adapter Priority'. Now, I am not 100% sure which setting you should use, but I think it should be [PEG/IGD]. I believe IGD = Integrated, PCI = PCI (NOT PCI-E) and PEG = PCI-E, but again, not 100% certain.<br />
<br />
Oh.. seems it's named a little different in your case. anyways, that IGD setting should be [PEG/IGD] I think.. try it.<br />
<br />
Hope that this helps.
Discussion Starter #33
thnaks for the power advice, however I only have the Maste CF card, not the slave so my power is fine for one card I think.!!! is 570 w enough?
Bod ***s rock
go to <a href="ftp://dlsvr02.asus.com/pub/ASUS/mb/socket775/P5RD2-VM/e2365_p5rd2-vm.pdf" target="_blank">this page</a> and it will tell you all you need to know
Is your psu on the list on ati.com ? Could be a rail issue ?<br />
I don't think it's the PSU. Even with a weak PSU, it would still boot, since at those times the card does not draw that much power.<br />
<br />
Whether his PSU is sufficient to run at 3D (when the card is indeed hungry) I don't know. I need to know the brand/model PSU for that.
When you have plugged the card in, and it doesnt post on the screen. Did you check to see if the fan on the card was working? Just to check if the card is dead or not.
Administrator
Make sure that the PCI-E slot if free of dust and that the Gold contacts on the Card are clean. Also try a CMOS reset. <br />
<br />
To do this look to your motherboard and remove the little bettery from it for 2 mins and then put it back in.
I think he got it working already <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
21 - 40 of 49 Posts
