Hi,
I have bought a custom computer with the fractal R5 define case also with an h100i.
I was wondering if I could go for the same build as here (finished build starts at 7:35)
https://www.youtube.com/watch?v=SRZIdbdcIiU
I want my h100i radiator to be mounted at the front intake and have the fan behind the radiator similar to the video.
I was wondering would it be possible to do so with the fractal 140mm fan behind the radiator, if not what could i do do make it possible ? (possibly purchase an extra 120mm case fan instead of using the 140mm fan)
Currently; I have the radiator mounted on the top (the default build) and it makes a lot of noise, thus my reason to shift the radiator to the front for front intake.
Thanks.
Thanks.
