[HELP]How to Overclock q6600+p5kpro
407 Views 7 Replies 3 Participants Last post by  Webster200x
Hello i want to overclock my q6600 to 3 Ghz but i can't get over 2.7 my system specs are
CPU: Intel Core 2 Quad Q6600 (Revision G0)
MOBO: AsusTek P5K PRO
PSU: Spire Jewel 750W
GPU: Asus EN9800GTX+
http://valid.canardpc.com/show_oc.php?id=527913
If someone can help it will be much appreciated
1 - 8 of 8 Posts
What is your VID and core voltage at now? Just bump up the voltage from what its at now (1.25 to less than 1.3 or so). You may also want to up your FSB voltage as well slighty. Make sure not to push it too far voltage wise and check your temps. Also do you have stock cooling?
Almost all q6600 should be able to hit 3ghz. I say give it 1.4v to vcore and see what happens.
all of them are auto i only did the CPU Frequency to 301*9= 2.7Ghz and yes i'm on stock cooling il try to give it some volts just hope that i don't have to reset the bios again
Edit : i'm now testing whit 1.40 VCORE
http://valid.canardpc.com/show_oc.php?id=527988
But it's too hot whit stock cooling 65-68 degrees celsius
Yeah 1.4v is way too much for 3.0. You would need 1.3 max probably. Try that and let us know.
ok il do that now and let you guys know and thanks for the support
EDIT: I Tryed 1.3 but my system wont start whit it so i'm back to 1.4 i think that i need about 1.38v il test later after il come back from work
i left my pc on whit prime for 8 hours on 1.40 VCore and no errors
http://img223.imageshack.us/my.php?image=proofc.jpg
i have VID 1.3250 and 1.40 VCORE is this ok or i need to change someting here ? and sorry for duble posting
Edit: this is what i have in my bios so what do i need to change
Ai Overclock Tuner - Manual
CPU Ratio Setting [09.0]
FSB Strap to North Bridge [AUTO]
FSB Frequency [333]
PCI Frequency [100]
DRAM Frequency [AUTO]
DRAM Command Rate [2N]
DRAM Timing Control [AUTO]
DRAM Static Read Control [Disabled]
Transaction Booster [AUTO]
CPU Voltage [1.40000]
PCU PLL Voltage [AUTO]
FSB Termination Voltage [1.20]
DRAM Voltage [AUTO]
NB Voltage [AUTO]
SB Voltage [AUTO]
Clock Over Changing Voltage [AUTO]
Load-Line Calibration [AUTO]
CPU GTL Voltage Reference [AUTO]
NB GTL Voltage Reference [AUTO]
CPU Spread Spectrum [Disabled]
PCI Spread Spectrum [Disabled]
1 - 8 of 8 Posts
