1 - 8 of 8 Posts
I just got my Tt Armor case and i'm getting it apart ready for paint....<br><br>
but there are plastic holders on the side for holding the 5.25" drives...<br><br>
How do i remove those suckers ? cause i dont want to break them....<br><br>
PIC! 'clickable'<br><br><a href="http://xs.to/xs.php?h=xs207&d=06403&f=IMG_0019.jpg" target="_blank"><img alt="" src="http://xs207.xs.to/xs207/06403/IMG_0019.jpg.xs.jpg" style="border:0px solid;"></a>
<div>Originally Posted by <strong>noshibby</strong></div>
<div style="font-style:italic;">Just push on the little plastic pieces that are holding it on and pop it off</div>
</td>
</tr></table></div>
to the inside ? cause when i push them towards above they are bending <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"><img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
from what i can see it lookst like the dark grey piece is holding it on..umm sorry if im not much of a help the picture was sideways..it looks as if you squeeze the two middle parts together and then it comes right off though im not entirely sure..
It looks like you just pop the two top ends out. Here is what i believe. can anyone second this.<br><br>
edit:here is the second one it looks like you push the tabs down and then the bottom should slide up out.<br><a href="http://assets.overclock.net.s3.amazonaws.com/b/ba/bad08215_vbattach32680.jpeg"><img alt="LL" src="http://cdn.overclock.net/b/ba/525x525px-LL-bad08215_vbattach32680.jpeg" style="width:374px;height:525px;"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/a/a7/a719b543_vbattach32681.jpeg"><img alt="LL" src="http://cdn.overclock.net/a/a7/525x525px-LL-a719b543_vbattach32681.jpeg" style="width:374px;height:525px;"></a>
I used a pair of needle nose pliers and bent the metal tabs out a bit to take mine off.
I used a small flat head screw drive and pushed up on those little tabs slowly. That worked for me. The very top one is a PITA to get back on. I had to unscrew the pull tabs on that one,<br><br>
IMHO, take everything off that can come off. take off the chrome spacer flex tabs that line the doors, take off all hardware, the PCI quick release bar, etc.....then the paint job will look great and wont have the other stuff painted.
Discussion Starter #8
thanks for the quick responce ! <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
i got it ! just pushed both (on the left) pins out and the rest would follow ! <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
im now trying to figure out if i can remove the plexi glass window.....
1 - 8 of 8 Posts
