1 - 3 of 3 Posts
The 2 127C readings are most likely readings from slots not being used as I am pretty sure nothing is that hot and I get 2 of the same readings. Same goes for the 1c, I do not think anything is that cold unless your using a peltier or TEC. The other 2 temps seem fairly reasonable so not to worry.
1 - 3 of 3 Posts
