hi guys i am about to panick, i have this build that i have been getting together to give as a present to a family member.
its made of a p6t deluxe v2, 920 d0, 6Gb g.skill 2000mhz, now the problem the system is not starting up, there is lights on the onboard power and reset buttons but when you press them nothing happens, eventually when it does seems its going to power up, all it does is spin the fans but no image , no lights on the undeneath the memory to say that its started up like it usually does.
it was workign fine about an hour ago
also this is all outside the case and its sitting on my desk on top of a anty static bag
any help??
i was giong to give it to them on wednesday
also i have tried the components on my evga classified and it worked so its def the motherboard
EDIT: to make matters worse, i juts spilled freeser one liquid coolant on the motherboard
this is so not my day. i supose the liquid wont damage anything as its non conductive? it did spil over 30% of the board but didint go inside any slots or anything
this may sound silly, but is the power button connector you are using connected properly? You said its outside on an anti static bag, so perhaps something as small as that could cause nothing happening.
Did you try only 1 stick of RAM? Try that. If 1 doesn't work, try another. I had brand new RAM go bad once. Just like you said. Worked on initial boot up, never worked after.
Check RAM sticks one by one(insert only 1 RAM stick)
Possible power supply issue?
edit: remove/unplug anything unnecessary, that means optical drive, hard drives, sound card, etc. Just have only mobo, RAM, CPU, graphics card, and PSU and see if it boots.
Overclock.net
