HELP: Loud Hum / Vibration
1333 6
So it's not my fans, I turned them all off and still have hum/case resonance. Could be PSU, Pumps/blocks, or HDD.
Any solutions? My PC is silent otherwise with everything being watercooled so I just don't get it.
1 - 7 of 7 Posts
try to disconnect all HDD. if the hum still there, turn your pump speed down or un-plug for a moment. if the hum still exist, try another PSU.
Reactions: alucardis666
I'll try it. Thanks!
Turns out it's my PSU. any recommendations for a replacement?
Seasonic Prime series? they're great
Discussion Starter · #6 ·
Seasonic installed and running great, no more hum!
1 - 7 of 7 Posts
