1 - 3 of 3 Posts
ok so i was oc'ing yesterday, hit a few unstable spots and my computer got hung up, and after i got to stable, my internet wouldn't work! I have the linksys wireless G w/ speedbooster router and NIC card. Internet upstairs and router work fine, but my nic card goes on and off, briefly connecting and disconnecting. when it does connect, it only connects to the router and not the internet. i even tried reinstalling the drivers.<br><br>
HELP!!!!!!
same problem happend to me, but all i had to do was go this<br><br>
type into the address bar<br><br>
192.168.0.1<br><br>
then it'll ask you for your name/pass...if you dont know, then press enter. Go to misc or something, might be advanced, and look for REBOOT
from the computer with the problem, i can't connect to the router config. i tried on the computer with working internet and i can't find the restart button. i'm trying to fix the card, not the router...
1 - 3 of 3 Posts
