1 - 9 of 9 Posts
well i think my stock cpu cooler is startin to lose its touch and its time for something new, i want a effective setup, im not lookin to spend a bank load..but i know its you get what you pay for. i dont want it to look all crazy stuff every where. main thing im look to cool is vga, cpu and mobo. please give any suggestions and what not. i just look on newegg and dont have a damn clue as what to get.<br />
<br />
thanks, steve
Do you want to stick with AMD and your current socket (S939?)? Are you open to other socket-types?
newegg doesn't have much of a wc selection. Check out the sticky about places to buy wc gear from.<br />
<br />
this would be a good setup w/o robbing the bank:<br />
<br />
cpu: apogee -$50<br />
gpu: maze 4 -$50<br />
pump: d5/mcp655 -$70<br />
rad: 77 bonnie heater core- $35<br />
tubing: masterkleer 7/16" ID -$10<br />
fillport: $12
SNERP!!!
<tr>
<div>
Originally Posted by <strong>Syrillian</strong>
</div>
<div style="font-style:italic">Do you want to stick with AMD and your current socket (S939?)? Are you open to other socket-types?</div>
</td>
</tr>
</table>
</div>Yep, I'm pretty sure this is the watercooling section not the "upgrade to conroe, then watercool" section.<br />
<br />
<tr>
<div>
Originally Posted by <strong>soloz2</strong>
</div>
<div style="font-style:italic">newegg doesn't have much of a wc selection. Check out the sticky about places to buy wc gear from.<br />
<br />
<br />
fillport: $12</div>
</td>
</tr>
</table>
</div>That would be perfect. Stick with an air chipset cooler
<div>Originally Posted by <strong>Snerp</strong></div>
<div style="font-style:italic;">Yep, I'm pretty sure this is the watercooling section not the "upgrade to conroe, then watercool" section.<br><br><br><br>
That would be perfect. Stick with an air chipset cooler</div>
</td>
</tr></table></div>
Wooah!! <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> You be right! *** was I doing? ...being normal <img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"><br><br>
Sorry.
Discussion Starter #6
well can i be a noob and you guys post the link of exactly what i need to buy..cause im gettin way to many things when i search for the stuff..i just dont wanna buy the wrong thing..<br />
<br />
thanks, steve
<div>Originally Posted by <strong>steve00ses</strong></div>
<div style="font-style:italic;">well can i be a noob and you guys post the link of exactly what i need to buy..cause im gettin way to many things when i search for the stuff..i just dont wanna buy the wrong thing..<br><br>
thanks, steve</div>
</td>
</tr></table></div>
Most of this is at Danger Den so if it doesn't link properly look there<img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps">ump,<a href="http://www.dangerdenstore.com/product.php?productid=175&cat=23&page=1" target="_blank">http://www.dangerdenstore.com/produc...&cat=23&page=1</a><br>
Danger Den :: Pumps :: DC Powered :: 12V DD-D5 Pump ....GPU WB:<a href="http://www.dangerdenstore.com/product.php?productid=150&cat=18&page=1" target="_blank">http://www.dangerdenstore.com/produc...&cat=18&page=1</a><br>
Danger Den :: Water Blocks :: Nvidia and ATI GPU and Ram Water Blocks :: Acetal Version MAZE4GPU HEATER CORE:<a href="http://www.dangerdenstore.com/product.php?productid=48&cat=14&page=1" target="_blank">http://www.dangerdenstore.com/produc...&cat=14&page=1</a><br>
Danger Den :: Radiators :: Heater Core Radiators :: Double Heater Core with Fittings....TUBING:<a href="http://www.dangerdenstore.com/product.php?productid=238&cat=33&page=1" target="_blank">http://www.dangerdenstore.com/produc...&cat=33&page=1</a><br>
Danger Den :: Tubing :: Tubing and Clamps :: 7/16" ID (5/8" OD) Masterkleer General Purpose Clear PVC Tubing.....FILLPORT:<a href="http://www.dangerdenstore.com/product.php?productid=56&cat=33&page=1" target="_blank">http://www.dangerdenstore.com/produc...&cat=33&page=1</a><br>
Danger Den :: Tubing :: Tubing and Clamps :: Danger Den Fillport......APOGEE CPU BLOCK:<a href="http://www.svc.com/apogee.html" target="_blank">http://www.svc.com/apogee.html</a><br>
Swiftech Apogee Extreme Performance Universal CPU Waterblock (3/8" and 1/2" barbs)
Reactions: Snerp
Discussion Starter #8
wow thanks for takin the time to get the links and stuff<br />
<br />
you guys are totally awesome!, steve
Hope it will help you some...If you have more questions come on back we will be glad to help, if we can...
1 - 9 of 9 Posts
