1 - 6 of 6 Posts
So after getting out the game for a while i still have a ton of badass watercooling parts
Bored and polished plexi pump tops on a d5 mains pump.
2x hardware labs nemesis gtx480
2x nemesis gtx 360
30 pwm modded Gentle typhoon fans
Loads of fittings 1/2x3/4. and resevoirs
Supremacy evo
Supremacy full copper
So i just gotta pick up modern blocks
And tubing and maybe fittings
Maybe fans?
Anyways i am only getting a 1080ti and 7820x so i dont need to go crazy and have more than 2 rads
I do oc the crap out of things
So im stuck between the
Anidees AI Crystal XL
And the thermaltake tower 900
As they are the only things i found that could possibly do push pull with my config. And are under 350 on newegg
Open to suggestions
Force User
2x nemesis gtx 360
Supremacy evo
Maybe fans?
Open to suggestions
I like the Anidees better than the tower. The TT Tower reminds me of a mini fridge, but it is just a personal preference.
With your components, why not CaseLabs, or may be Lian Li V3000?
And post a build log! :)
My last major WC build was in late 2013 and I used a Phanteks Enthoo Primo ... if I did it again today, would probably use same model ... thing is, even then my goal was reduced noise .... I overclocked the bejeezes outta everything but I hit the voltage wall while the temperature wall was still some distance away. Sound is undetectable even during stress testing w/ 420 + 280 rads. The case coming with 5 market leading fans left me only needing to buy 11 more.... 10 on rads and 6 case fans using 4 temp / rpm curves, 1 for the dual pumps, one for each rad and one for case fans.
1 - 6 of 6 Posts
