1 - 9 of 9 Posts
i desided to get a water cooler but only got 70 MAX i know they are pricy but is there a way to buy 1 ?or make 1 ? or i was thinking of buying a termaltake i think u can extend it ,IF U GOT 1 u dont want maby we can make a deal?
I would strongly suggest, either saving more for a good WC setup, or if you really want better temps, and have only $70 to spend, then get a top end air cooler for around 45-50. Like the BT or tuniq tower. Either will outperform (yes thats right, outperform) a cheap water system, and is cheaper.
what about this 1?isnt this upgradeable? aka adding more redeaters?<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835106078" target="_blank">http://www.newegg.com/Product/Produc...82E16835106078</a>
Save at least $150 first
Discussion Starter #5
i cant u see every time i get money it desapears,cuz some1alway needs it,if i dont use it my mom will and she will WASTE IT ON JUNK<br><br>
EDIT: that why i wanna buy <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835106078" target="_blank">http://www.newegg.com/Product/Produc...82E16835106078</a> and upgrade it later
Well, if you were to upgrade that TT system, you would litterally be replacing EVERYTHING on it... If you want wc, and need to speed the money as you get it to keep it away from your mom... Just buy part by part like i did. Buy the pump now, then the block, then the rad, then the tubing... an boom you have a sweet wc system.
<div>Originally Posted by <strong>vtech1</strong></div>
<div style="font-style:italic;">i cant u see every time i get money it desapears,cuz some1alway needs it,if i dont use it my mom will and she will WASTE IT ON JUNK<br><br>
EDIT: that why i wanna buy <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835106078" target="_blank">http://www.newegg.com/Product/Produc...82E16835106078</a> and upgrade it later</div>
</td>
</tr></table></div>
As other posters have pointed out you need at $150.00-$200.00 to get a decent set-up....Stay away from cheap kits, you would be better off getting high end air cooling..These Swiftec kits are good and the are on sale now...........[......Any less then these are a waste of money IMHO....<a href="http://www.svc.com/h20-220-apex-ul.html" target="_blank">http://www.svc.com/h20-220-apex-ul.html</a><br>
Swiftech Apex Ultra Dual 120mm Water Cooling Kit............<a href="http://www.svc.com/h20-120-premium.html" target="_blank">http://www.svc.com/h20-120-premium.html</a><br>
Swiftech Premium 120mm Water Cooling Kit
man i would find a good spot to stash your cash that way you can save it if you can<br><br>
but if not i agree with posted above and get a decent air cooling or go part by part, a decent air rig and youll see a much improvement over your temps you have now
SNERP!!!
Yup, go big or go home <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br>
THe Scythe Infinity is on sale now if you need something right away.
1 - 9 of 9 Posts
