1 - 5 of 5 Posts
i got 200 - 250 to spend MAX and can make more when i sell this board i need something that can oc GOOD ,now i got atracked to
http://www.newegg.com/Product/Produc...82E16813136159
http://www.newegg.com/Product/Produc...82E16813136164
http://www.newegg.com/Product/Produc...82E16813136152
witch 1 of these 3 boards will be lucky to go home with me tomarrow?
now the other thing is i wanna reatch 3Ghz on this sandy so what els do i need i need ?
cooling and power right? what can i buy? i want a WC system
you can't get WC for less than 250....sorry man.
Get a DFI Lanparty Ultra-D or SLI-dr. Best overclocking 939 board period.
For cooling look at a tuniq tower if you can find it...otherwise, a scythe infinity or a thermaltake BigTyphoon will do you fine...
You are better off just getting a good air cooler like the Big Typhoon or a Tuniq Tower than a cheap Watercooling, it will perform better.
1 - 5 of 5 Posts
