1 - 11 of 11 Posts
I'm currently trying to purchase a motherboard that goes with the processor<br />
Intel Core 2 Duo E6300(1.86GHz) <br />
<br />
I was wondering if someone can find me the BEST and most STABLE motherboard with the LOWEST price as possible. I think someone has researched on that already. I am in no need of overclocking needs. Just stability and will work without much technical problems like burning, or explosions.<br />
<br />
Thanks in advance.
Any specific features you need (such as RAID?)
How about this:<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813138035" target="_blank">BIOSTAR TFORCE945P Socket T (LGA 775) Intel 945P</a> $82.99<br />
<br />
Here is an mATX board with onboard video:<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813131041" target="_blank">ASUS P5L-MX Socket T (LGA 775) Intel 945G Micro ATX</a> $75.99
Discussion Starter #5
More perferences, Non MICRO ATX boards. I kind of need -VM Video and Multimedia, but if not able, recommend me a video card too. The person isn't much of a gamer, but needs multitask, and medium intensity of game. Budget is around ~150$
With onboard video, and ATX format:<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813128018" target="_blank">GIGABYTE GA-965G-DS3 Socket T (LGA 775) Intel G965 Express</a> $144.99<br />
<br />
If dedicated card, the Biostar I listed before will do fine for $82.99 and then something like this <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814121550" target="_blank">ASUS EAX1300PRO/TD/256M Radeon X1300PRO 256MB GDDR2</a> as video card for $68.99
Reactions: azn22panda
It should. Unless it's a really crappy generic one <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Chozart has layed it out once again <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
The system i'm currently running never breaches 230W, in that case 350W should do you well, as long as it's not generic, like Chozart said.
1 - 11 of 11 Posts
