Help me decide sound card!
699 Views 10 Replies 8 Participants Last post by  psi_guy
Since I have little as none knowledge on the Sound Card section, can anyone tell me the difference, advantage and so on about the following cards.
It will be used for gaming and music!
Creative SB X-Fi Titanium Fatal1ty Pro PCI-Express
Creative SB X-Fi XtremeGamer Fatal1ty Pro PCI
Creative SB X-Fi XtremeAudio PCI-Express
1 - 11 of 11 Posts
save yourself some $$ and dont fall for those fatality editions your just paying extra for the branding the xonars are good or the xtreme music xfi ive used them before and I can vouch for these cards at least
Reactions: 2
Thanks for the infos! Also if you know about some good cards on the about same price range as the cards I put in, please let me know. They will only be used for games and music, must be extremely good with both. I've got both Sennheiser HD595 and Creative 5.1 system.
** EDIT
ASUS Xonar D1 seems to be getting really great reviews, maybe I'll "hit that" unless you've gonna name some better once for same or little bit more $$..
If you're going to opt for the ~100 price range, I would go with Juggalo's recommendation and go with a Xonar over the Xi-Fi Titanium.
If you want a good soundcard for the headphone I recommend the Asus Xonar Essence STX. But that really depends on how much you want to spend on it.
Why the Xonar over the Titanium? That's the card I wanted to get. And I also am not that knowledgeable when it comes to audio cards.
How has it been doin with games?
its a good card for gaming specially with your "cans" love the pre amp feature for the headphones gives it a lil more umpf
i have been using the creative sound blaster x-fi xtrememusic card for the past couple of days and love it. i grabbed mine when they were on sale at amazon for $30. best purchase ever.
1 - 11 of 11 Posts
