Hi all,
First off, I am new here after lurking for about a week as I build my first home-built PC. So please forgive any mistakes on my part!
I am putting together a PC for gaming and light office use. I have settled on the Intel Core i5-4670 3.4Ghz processor, with 8GB RAM. However I am having difficulties with the motherboard. I'm wondering if you could recommend one?
MSI H87-G43
Gigabyte GA-H87-D3H
and MicroATX:
MSI H87M-G43
ASRock H87M Pro4
Gigabyte GA-H87M-D3H
Asus H87M-E
... or any others you might recommend.
My case will fit either size but I don't really have a pressing need for the full size, I guess? The difference as far as I can make out is you get more ports on the full size boards.
I will be putting an nVidia GTX 770 (or POSSIBLY 780, but probably not) onto the board.
I was originally considering the z87 and the 4670k CPU to allow for potential overclocks down the road, but budget meant this is something I've decided against for now.
I am in the UK, if this helps.
Thanks a lot for your help.
MSI H87-G43
Gigabyte GA-H87-D3H
and MicroATX:
MSI H87M-G43
ASRock H87M Pro4
Asus H87M-E
