Make it go higher!
Originally Posted by x2s3w4 ![]() If you can run Intel Burn test for several passes, you should be golden. Watch your temps, they will get hotter than Prime. Edit: Forgot to say that is awesome voltage for 3.6. Nice job. If you can get higher, that would be epic. |
