Take a look into this one: Antec ISK 300-65
It may not have a 3.5" hard drive bay but I'm sure you can find an adapter or something which converts 2x 2.5" bays into one 3.5" bay. They make the opposite, I'm sure.
The only thing about the case: 65W PSU is included and you may need more power (more £ needed to spend) and the PCI slot at the back is small so you will need a tiny graphics card, unless using onboard video?
Good luck
PS. Welcome to OCN!
Good luck
PS. Welcome to OCN!
