seems high... look in my sig for a link to configs with the E2160 in em - very helpful info that ought to give you an idea of settings to try.
I know these newer chips are volt-hungry, but jeez, that is quite high, and i do not recommend passing 1.5V+ through her for too long, if you want her to last. are you not willing to back off of 3.2 to 3ghz? seems your CPU might have hit an FSB wall / that stage where she needs a huge boost for minimal gain..
mine took 2.4ghz at stock volts, but i needed to go to 1.425 for my current OC.
-e- try looking at the Gigabyte P35 DS3L thread if you have not already
