you need to make the usb drive bootable.
Originally Posted by dralb ![]() There is a HP format tool to make the flash drive bootable. You can then use XPlite to remove anything you don't want or need. (like language packs, modem drivers etc.) Once you format the drive, put XP on it, boot from USB and it is the same as doing it from a disk. http://files.extremeoverclocking.com/file.php?f=197 |
