Well here is where we are sitting at..my specs below..
I am overclocking after upgrading / formating a bit and I am currently at..
CPU FSP 340 (2723mhz) (2.1ghz default)
Vcore 1.312 (one step up from default)
GPU Core 622 (500 default)
Mem 936 (800 deafult)
And I am stuck..If i up the memory on the gpu and do the artifact test (Atitools) I see little yellow bumps. So I lower it.
The same goes for the GPU core, I see some bumps so I lower it..
My E6400 however, I have tried raising the vcore higher (all the way to 1.38) to try to get over 340 FSB but it just reboots before I can even login sometimes.
Any ideas?
Havent messed with anything else other than vcore...
Thanks in advance!
*On a side note. The memory i bought was advertised 5400 speed...however it reads as 4300 in my POST msg..One time it even read 3400! What is going on?
Any ideas?
Thanks in advance!
